Uygar
Mitsubishi Lancer (evo değil) :)
Bu konuda 76 ileti var
[img width=800 height=531]http://files.conceptcarz.com/img/Mitsubishi/Mitsubishi_Lancer08_manu-07_023-1024.jpg
[img width=800 height=531]http://files.conceptcarz.com/img/Mitsubishi/Mitsubishi_Lancer_Evo_Intro_DV-07_DAS_06.jpg
[img width=800 height=531]http://files.conceptcarz.com/img/Mitsubishi/Mitsubishi_Lancer08_manu-07_i020-1024.jpg
2008 Mitsubishi Lancer
Year 2008
Make Mitsubishi
Model Lancer
Engine Location Front
Introduced At 2007 North American International Auto Show
Engine
Engine Configuration I
Cylinders 4
Engine MIVEC
Aspiration/Induction Normal
Displacement 2.00 L | 122 cu in. | 1999.6 cc.
Valvetrain DOHC
Horsepower 152.00 HP (111.9 KW) @ 6000.00 RPM
Torque 146.00 Ft-Lbs (198 NM) @ 4250.00 RPM
HP / Liter 76.0 BHP / Liter
Fuel Type Gasoline - Petrol
Standard Transmission
Gears 5
Transmission Manual
Optional Transmission
Gears 6
Transmission Manual
Sportronic
Dimensions
Passenger Volume 94.801 cu. ft.
Seating Capacity 5
Doors 4
Exterior
Width 69.401 in | 1762.8 mm.
Wheelbase 103.701 in | 2634 mm.
Front Track 60.201 in | 1529.1 mm.
Rear Track 60.201 in | 1529.1 mm.
Brakes
Front Brake Size 11.601 in | 294.7 mm.
Rear Brake Size 11.901 in | 302.3 mm.
Tires / Wheels
Tires 205/60 R16
Wheels 5-spoke 16-in. alloy
2008 model Mitsubish Lancer. Evodan pekte farklı durduğu söylenemez ;)
biri parlament mavi öteki fişne çürüü baskada fark yok :tey:
First Mitsubishi in North America with a CVT
All Lancer models come with a standard crisp-shifting 5-speed manual transmission. The new-generation Lancer is the first Mitsubishi in North America to offer an optional continuously variable transmission (CVT) in place of a conventional automatic transmission. When equipped with the CVT, the Lancer GTS exclusively features a 6-step Sportronic® mode that allows the driver to manually control transmission operation using magnesium steering wheel paddle shifters - a first in the segment.
In contrast to a conventional automatic transmission, which uses fixed gear ratios, a CVT operates on a pulley system that allows an infinite variability between highest and lowest available ratios with no discrete steps or shifts. A CVT smoothly adapts to changing vehicle speeds, allowing the engine speed to remain at its level of peak efficiency, helping to improve both fuel economy and exhaust emissions.
Çeviri yapmak isteyen yapabilir. Yada direk ingilizce bilenler anlasın o da yeter  :tey: :tey: :tey:
Kabin içi çok zayıf bence, ama dışıda bi o kadar güzel.
bu Mitsubishi ne zaman iç mekan yapmayı öğrenicek acaba  8:)
içi bence gayet güzel ve şık
direksiyondaki vites kolları da ayrı bir hava katmış ;)
Bence de fena değil... Yalnız bir tek direksiyonun sol tarafında göğüslükteki şeritlikteki materyal kırışması gözüme battı...
bence o değişebilir versiyona göre veya isteğe bağlı olarak :-\
Olabilir, oraya bizdeki gibi siyah veya karbonfiber görünümlü veya sağdaki gibi krom (ben sevmem gerçi) bi şerit gelirse güzel olur...
Hazır başlamışken bi de şu klima düğmelerinin altındaki oval kabarıklığı da iptal etsinler :D
2008 model bir araca bakıyorum ama 2004 model mazda'dan üstün hiçbirşey görmüyorum :nea:  karoser yapısı bile ufak tefek değişiklikler hariç mazdanın kopyası gibi geliyor bana....
Ben hiç beğenmedim güzel olmamış zaten ezelden beri ne hikmettir bilmiyorum ama Mitsubishi markasıyla kanımız ısınmıyor... ??? Sadece tek bir artısı var oda bir Japon markası olması... ;)
evet mazda3lerden fazla bi farkı yok gibi duruyor. ama 2008 de de mazda3 te bi değişiklik yapılacağını sanmıyorum :) 2009 u bekleyeceğiz sanırsam.
Kaldırıp atılacak gibi bir arabada değil  :tey: :tey: :tey:
Piyasada ne arabalar var... 8:) 2009 u beklemene gerek yok. ;) git birtane 320i al yada 120i al olmadı cooper s al  ;)Benden sana tavsiye. ;) Artık bana araba soran arkadaşlarıma bunları tavsite ediyorum.Bundan iki ay öncesine kadar tek taraflı bakıyormuşum bunu bende yeni anladım....
Bana VOLVO yu çağrıştırdı biraz daha özgün bir tasarım yapabilirlerde o kadar çok beğenmedim , çirkin değil ama .....( ama sı var )  :)
